Na Belorusu se nešto podešava komparaterom?![]()
Da i to dosta stvari , zazori na prednjoj vuci konusnih lezajeva (ravan most) prednji diferencijal, zadnji diferencijal itd. To sto "ofrlje majstori" rade od oka zato vecina kad prodje asfaltom ne znas jel prosla neka srotara ili traktor
![Haha :haha: :haha:](/styles/default/xenforo/smilies/poljoinfo/haha.gif)
Evo ti nekoliko namjestanja na prednjoj vuci
а) adjust pretension in bearings 2, 3 of final drive driving gear 4, which must nor exceed 0.04mm
(Figure 5.33).
g) check and, if necessary, adjust dimension 40.7±0.15 mm from final drive axle to surface “А” of
differential.
h) put differential inside body 3 and adjust pretension in bearings 6, which should not exceed 0.10mm.
j) put required stack of spacers 3 to adjust lateral clearance in the engaged gears of final
drive 4, 5.
Clearance should be within 0.18 – 0.46 mm, which corresponds to angular movement of flange 1 (for diameter of bolts position), correspondingly 0.3 – 0.65 mm.
Ja znam neke majstore koji prvo nemaju ni pojma da se to namjesta , ti meni ne rade
