I MTZ meri na tockovima. U praksi MTZ 105 je jaci od stranih brendova iste snage.
Nemoj biti tako siguran da je jaci taj kojem pumpa nije dirana.
Deutz je jedino dobar motor,menjac je katastrofa ocas posla samelje nesto...JD je jedini koji snagu meri na tockovima zato i ide tako.
[TABLE="class: tdData3, width: 100%"]
[TR]
[TD="class: thdr, colspan: 2"]OCED Tractor Test 1462:[/TD]
[/TR]
[TR]
[TD="class: tfld"]Nebraska summary:[/TD]
[TD="class: tdat"]145[/TD]
[/TR]
[TR]
[TD="class: tfld"]Type:[/TD]
[TD="class: tdat"]Diesel 16-speed 4WD[/TD]
[/TR]
[TR]
[TD="class: tfld"]PTO power (rated engine speed):[/TD]
[TD="class: tdat"]112.20 hp [83.7 kW][/TD]
[/TR]
[TR]
[TD="class: tfld"]PTO fuel use (engine speed):[/TD]
[TD="class: tdat"]6.9 gal/hour [26.1 l/hour][/TD]
[/TR]
[TR]
[TD="class: tfld"]Drawbar power (max):[/TD]
[TD="class: tdat"]103.40 hp [77.1 kW][/TD]
[/TR]
[TR]
[TD="class: tfld"]Drawbar fuel use (max):[/TD]
[TD="class: tdat"]6.8 gal/hour [25.7 l/hour][/TD]
[/TR]
[TR]
[TD="class: tfld"]Drawbar pull (max):[/TD]
[TD="class: tdat"]18,295 lbs [8298 kg][/TD]
[/TR]
[/TABLE]
[TR]
[TD="class: thdr, colspan: 2"]OCED Tractor Test 1665:[/TD]
[/TR]
[TR]
[TD="class: tdat"]132[/TD]
[/TR]
[TR]
[TD="colspan: 2"][/TD]
[TD][/TD]
[/TR]
[TR]
[TD="class: tfld"]Test Date:[/TD]
[TD="class: tdat"]April 28 - June 19, 1993[/TD]
[/TR]
[TR]
[TD="class: tdat"]Diesel power shift 4WD[/TD]
[/TR]
[TR]
[TD="class: tdat"]111.59 hp [83.2 kW][/TD]
[/TR]
[TR]
[TD="class: tdat"]6.4 gal/hour [24.2 l/hour][/TD]
[/TR]
[TR]
[TD="class: tdat"]93.53 hp [69.7 kW][/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD="class: tdat"]14,507 lbs [6580 kg] [/TD]
[/TR]
[TR]
[TD="class: tfld"]Max pull gear:[/TD]
[TD="class: tdat"]5[/TD]
[/TR]
[TR]
[TD="class: tfld"]Test report:[/TD]
[TD="class: tdat"]PDF file[/TD]
[/TR]
[/TABLE]
" on ide kao medo" wajs milerJa gledam u data-njiva,rogonja je rogonja.
Druze, da imas akumulator od 97 ampera, upalio bi taman motornu kosilicu.Nemam tih problema, imam od 97 ampera akumualtor i dirko sa njim pali ekstra...da se co'ek uplasi kako sastavi....
Onda ocigledno je do pumpi. Taj 1025 sam orao nekoliko krugova sa njim. Ide kao mevaca, plug 757.30 vuce kako god hoces. Traktor je 2006 i ima oko 3500 sati.
I gde moze Belarus 1025 da se nosi sa John deerom 6400 ili Fendtom 311, deutz Dx 110 ili Case 5130?
