Jabuka
Kakva je za sopstvene potrebe u amaterskom vocnjaku jabuka elstar.
Nasao sam da je jedan od roditelja zlatni delises .
Mislim se da zasadim nju ili melroze.
Imam u amaterskom vocnjaku zlatni delises, ajdered, jonatan i po jednu kozaru i greni smit.
Procitaj pa onda idi na karticu identification
Koristi taj sajt imas opise sorti, utiske ljudi, sve informacije o dosta sorti jabuka - ja bolji sajt nisam nasao
To kad napisu red ispred neke sorte to je ustvari mutacija te sorte sa boljom obojenoscu ploda
Meni licno topaz nista posebno od sorte,
Merlose mnogo bolja - jonatan x crveni delises
Pinova, liberty, calypso(redlove) to su po meni valjane sorte - bar ovde kod mene
Sve tri sorte redovna rodnost, nisu bujne, poprilicno otporne i sitniji plod - a pinova pod nekom zastitom trebalo bi da moze dugo da se drzi u gajbama
Nicogreen i goldrush su mi jos u ispitivanju
Prijedorka, sumatovka, kamenica od starih sorti i francuski beli kalvil - isto jos u ispitivanju
Jako ukusa ali osetljiva honeycrisp
I jos trazim arcansas black, elision orange
  • Po chat gpt lista sorti jabuka najotpornijih na bolesti
  • Liberty
    • Resistance: Excellent resistance to apple scab, cedar apple rust, powdery mildew, and fire blight.
    • Flavor: Sweet-tart, with a crisp texture.
  • Enterprise
    • Resistance: Highly resistant to apple scab and moderately resistant to fire blight and powdery mildew.
    • Flavor: Firm, crisp, with a balanced sweet-tart taste.
  • Goldrush
    • Resistance: Strong resistance to apple scab and good resistance to powdery mildew.
    • Flavor: Sweet-tart, rich, and complex, improving in storage.
  • Florina (Querina)
    • Resistance: Highly resistant to apple scab and moderately resistant to powdery mildew and rust.
    • Flavor: Sweet, aromatic, and crunchy.
  • Freedom
    • Flavor: Juicy and mildly sweet with a refreshing taste.
  • Pristine
    • Resistance: Very resistant to apple scab and moderately resistant to powdery mildew and fire blight.
    • Flavor: Early ripening, sweet-tart, and refreshing.
  • Topaz
    • Resistance: Excellent resistance to apple scab and good resistance to other fungal diseases.
    • Flavor: Tangy, crisp, and aromatic.
  • Crimson Crisp
    • Resistance: Strong resistance to apple scab and moderate resistance to other diseases.
    • Flavor: Crisp, sweet, and juicy with a rich flavor.
  • Santana
    • Resistance: Good resistance to apple scab and suitable for organic production.
    • Flavor: Sweet-tart, refreshing, and aromatic.
  • Williams Pride
    • Resistance: Highly resistant to apple scab and moderately resistant to rust and powdery mildew.
    • Flavor: Early ripening, sweet with a hint of tartness.
U januaru posađene tri jabuke (idared, granny smith i topaz). Mojom greškom, jer nisam naveo koju ću podlogu, dobio sam sve tri na M9. Gledao bih da izbjegnem vreteno ako je ikako moguće. Voćnjak je mješoviti i ekstenzivne je prirode. 40ak raznih vrsta na 5x5 razmaku otprilike. Da li M9 može izgurati neku piramidu, palmetu kosih grana isl?
Tri autohtone su na 106, tu pretpostavljam ne bi trebalo biti problema sa piramidom, da li običnom ili poboljšanom?
Da li je kasno da sutra orezem i skratim dva stabla jabuke kod mene u dvoristu ( vec je pocelo da pupi ), a imam i grane koje su otisle visoko u kablove pa bih i njih po dobro skratio.. Da li cu napraviti neku stetu jer sam zakasnio to jest nisam orezao na vreme ?
Imam par stabala jabuke za svoje potrebe i dosad neznam da sam ikad docekao u jesen da ostane koja jabuka, dobro to ocvati i rodi ali tokom leta sve otpadnu, pretpostavljam da ih treba prskat , ne znam cim i kad pa ako neko od vas iskusnih ima volju da mi pojasni sta sve da upotrebim da bih nesto sacuvao
Ако имате пар стабала онда немојте да прскате па макар и не родиле... прскано можете да купите у продавници.
Пробајте да нађете старе сорте на дивљој подлози, мада ни то не даје гаранцију да ћете добити плодове.
Ја имам неколико стабала које не прскам. Плодови су шугави, кврави и црвљиви... али су здрави... опет пишем... прскано имам и у продавници.
Pogresan izbor sorti za takav nacin uzgoja.
Potrazite kalendar zastite za jabuku.
Nazalost zaboravi na njih, 99% je uzrok opadanja crv iliti jabukin smotavac. Preparati protiv njega imaju kratkotrajno dejstvo, otprilike kao sprej protiv musica, moras da prskas prakticno svakih 7-10 dana od maja do avgusta. Eventualno ako rano odradis tretman u maju mozda nesto i ostane
Јабукин смотавац је лептир. Где су предатори да јуре лептире? Птице? Паукови?
Поставити на сваком дрвету клопку као за осе... мало пива и мало сирћета, мало шећера и воде... даве се лептири у томе... и осе и стршљенови... важно је да има мало сирћета јер то одбија пчеле.
Pa ja prskam jabuke i kruske maximalno 4 puta(sljive bi moglo i 2 puta) i uvek imam roda da berem, a sobzirom koliko se puta prskaju u velikim vocnacima ovo moje je zaista minimalno prskanje .
Bez prskanja tesko da bi nesto ostalo.
Sa cim prskate ? Ja imam dve jabuke, ova jedna nisam siguran koja je sorta, uvek ostane jabuka i dobre su, od zlatnog delisesa nikada nista nismo pojeli, rodi dobro i uvek sve pospada i propadne dok dodje do branja..
Posadi grenny njegov plod je tvrd pa ga puno i ne diraju crvi, redlove calypso ne znam dal sam video crva u plodovima.
Kod grenny-a je dobro da mu je krosnja redja posto zna zakaciti pepelnicu a opet plod se zna ispeci ako je ceo dan na suncu .
Tako da za neki uzgoj bez prskanja treba joj naci mesto da je ne tuce ceo dan sunce i bude ok.
Imas u BiH rasadnik Ninic sortimen su stare sorte - posadi koju zeleniku ako zelis jabuku bez prskanja
Koliko sam upućen, što se BiH tiče, najkvalitetnije sadnice su iz rasadnika u Srebreniku. Ja sam ove godine naručio pedesetak sadnica svega, što iz tog rasadnika, što iz rasadnika Agromedžik, pa Vučković Prijedor, nešto iz Hercegovine i meni kao laiku najzdravije (pogotovo korijenov sistem) su izgledale upravo iz Srebrenika. Imaju dosta autohtonih sorti jabuke na mm106, a i kruške na divljaci.
