Yes the p/shift controller monitors the pressure decay in the off going pack & the pressure build up in the oncoming pack, obviously to make for smooth shifting you have an overlap, once the off going pressure drops so far the switch will activate & the controller on picking up this signal will open the on coming solonoid. If it did this too late the clutches would bang in, too early & you they would lock. Both engaged at the same time.
What you really need to do from here is a regulated circuit leakage check with a flow meter plugged into the priority remote valve ( number 1 ) This test shows up any leakage within the regulated circuit.
Da li vredi ovo necemu ima li ko od forumasa ovakav model?
https://www.polovniautomobili.com/traktori/9391518/case-ih-895xl
Ko je bolji od ova dva?
https://www.polovniautomobili.com/traktori/9365794/case-ih-5120
da li si ti radio kalibraciju menjaca na new holanda ?Mislio sam na kalibraciju kvacila. To se radi kada trza prilikom promena brzina.
Zasto li ga prodaje?Nema nesto puno sati.https://polovniautomobili.com/traktori/9366077/case-ih-maxum-140
