Sa čim perete poljoprivrednu mehanizaciju? --> perači pod visokim pritiskom.
NbmcEo0ahYMxeqFObko0nMvKh667kaj06_T9LCfsIbvEhjHWHqTz61_yEjk77N4W1uJWnEf2FwLVO1W2uE9oWQm8NuBJbVRd7SXKw_3hsyzREk5kNKs8vUBWdnGlD_qA21TdLZkwnkkiHXn5c2j2pXjsO5xr2s3WOfFuVLaiiynaU_m0kLmA-kuO4q7CS8MIUc3h3aPvayQa3HWIa3lXZPaEmuYikXgGPdTUTwtoBxkNon37OgBK8H3qrxA7881G8MtoGcHQgxJ2ZqHHZ0AxgjvaLGu_ehrhmTvfyry72xO7-Lpo8BRXVuBlL8FQmqVn7mdSo_ElUIX8reBpQIZ-wBPS9EILFFmE0mrEPx-RvnSfcv_dAdkOwvbCzlxH6-Vd3wiGz2791SVJR_PqbYp4WZ6u7pQOANkmCncArzY5PpSIzPwD7NwD_4hGJ7DKWZo9hjqxeHKpqgJfG5LdiOnmqJlwZY7Sp_I70sch1tqnOzA2Aes4sI_e0htuWGbF9o6iCdRECtnsQm4my_NHqCiZREgp1oE93qIsPNdWIRPtHUi-k-7mDJrTRJH0eIKlbNQWK79-D3eAr9q3iLhzUL-9QSefnB4gwsgJ4I-zdGUozNmH8Uk6TwSY896rcDGiebB_oYcBZAM0E2ExjBwXXves3CyLcNgiDB2HvNTepYbZknU4YqASTJyPWA=w529-h939-no
o-VfJD8Xbe9xzjLHXk-QtygqPR7QGNQUVzjCfWw4d4TQGYiZjPaLGujxUWgnJ_SF2w3bdsQ1FAVexUUt5LPWUX3xnMJe-fKBK8ayaiohC61npWe10DOhKSwJAAx-_0Jzp2jMOyQNwYqJQLojXjzy0LD3zNrh_6Y_8VVh0LlOMu4gmk5rsN_QzoX2JHkqBqmHqa5aQ7zj1Rwne8tsYZuSCmXp0BAKcms5UJUd4gaszTQqWDYSese3LBdnjXOJjrC1Om2PfwroihT8r1tuqDBT759vJSZMhtppHsYKGKr15kVtgTboqQgRIjaX9B3u_S1G-gimGUYD2MCD3DqocBRxt6YTo5l92C2oMP2wwEjPHuNv10bIrlRsMC6qT8KlcWhBbolmuyTf2NYxqHoMv-ADptu-Y8hGZyyjL-4f2Y99pUbpB31JtJSH6-cGhenCpkCOH4aed-XGWUu60KcSzsfRwrrpGSH4KPrG-ZQv4zmdVxjHE-xi2aThXJBbHJPAXG2yQYN54FO4lvE23YnyWQJfrS5z5knaokXN62yPQeVezq7U849iairwedzXVf-OkcbaRRTN4eA1bYmTNwJSynDTjo_bGLgUzSuqQq775nyluAsFbpmNUNESu5tC0M1g4ZJOdJPlIeQmYgaQvKs9TCY4API52efF32qILQZckSIaGs7iEDJmP7V6lg=w1670-h939-no
Jel mi moze neko reci nesto vise o ovoj masini? Ne mogu izguglati,jacina motora me najvise zanima.Inace skoro sam pazario.
Sa cime perem kaljavu gvozdjuriju?:) tehnika je bitna...prvo oteram kod Luke pa on izbaci dve gajbe ladnog i dovedemo 2 babe po 25g da ribaju felge dok mi zveckamo sas`flase😎
Ja ih vidim.
Tombice, da bi postigao tih 250 bari, što piše na mašini, i imao tu potrošnju vode od 35lit/min mora imati minimum 8kw motor. Ma i više.... Životinja od perača.... videćeš.
Mozda je pisano ali nenadjem,da li koristite one activne pene ili tako nesto za pranje mehanizacije?
Ja koristim bez kontaktno sredstvo i radi extra posao. Engleske je proizvodnje,mogu kasnije da slikam ako nekom treba
Da li sme sa peračom da se opere hladnjak klime? Skoro je zabetorniran prašinom negde teško i kompresor da probije pa s e mislim da ga peracem operem.
Bolje probaj prvo crevom sa vodom da ga ispiras i izduvavas kompresorom.Može i peračem ali pažljivo,to saće se jako lako pokrivi i deformiše.
Aco, može peračem ali smanji pritisak na jedno 50-ak bari, ako može, i malo se udalji. Ako vidiš da radi radnju operi tako. Ako ne onda se postepeno približavaj. Pritisak ili ne diraj ili pojačaj ali i budi oprezan.
Tako sam i mislio, manjim pritiskom. Prilično je stvrdnuto, bojim se da se i tako ne deformiše. Ovako bi voda malo omekšala prašinu. Nema žurbe. Inače već sam dve kile prašine izbacio iz filtera klime i kabine. Sve ću filtere zameniti, mislim da je tako najbolje.
Gde kupujete gumene manžetne za puromate?
Konkretno mi treba po 3
15*24*5
15*22*5
Dimmer sipas u špric i isprkas mašine. Posle samo isperes dal sa crevom ili puromatom. Nema ni potrebe za četkom.
Gde ce to sa crevom da ispere, treba to pod visokim pritiskom to sve jako lepo skida i masnocu.Ja imam jedan Karcher pod velikim pritiskom i imam jedan obican puromaton razlika kao nebo i zemlja sa ovim obicnim slabo radi ali sa ovim karcherom ubija kako skida.
Zdravo hteo bih da vas pitam nesto.
Letos sam radio busotinu za vodu i ubacio sam pumpu koja stvara pritisak od 10 bari.
Pa me je zanimalo postoji li mogucnos da na kraj creva nekako stavim pistolj za pranje, dal bi to radilo posao?
Da direktno okiten koji izlazi iz busotine reduciras i zakacis na njega crevo, pa na crevo pistolj? 10bar je 3x jace od optimalnog pritiska u vodovodnim cevima, tako da bi to radilo mnogo mnogo bolje nego bastensko crevo sa onim pistoljcetom za njega.
Послато са SM-J730F помоћу Тапатока
Da tako sam nesto mislio da uradim.
Samo bih bio problem sa pumpom, cim je upalim morao bi da bude pistoj otvoren kako bi isla voda da pumpa ne izgori kad nema gde da salje vodu. Izbaciva 150l u minutu, trebali bi da bi radilo to posao.
Moj predlog je da se ostavis te zamisli. :) Sve i da resis prepreke, 150l u minutu je da napravis poplavu bilo sta da peres. :D
