Ok, ovo je prva stvar gde imamo drugacije vidjenje stvari.Veoma sam zauzet poslednjih dana pa ne stizem da se detaljnije pozabavim temama koje ste pokrenuli.
Kratko,evo javno dostupnih podataka CIA u vezi Kosova
https://www.cia.gov/library/publications/the-world-factbook/geos/kv.html
Podatci o Srbiji
https://www.cia.gov/-library/publications/the-world-factbook/geos/ri.html
Prosecna starost stanovnistva Srbije,neslavno 24 mesto na svetu,sa staroscu od preko 42 godine.Kosovo je znatno mladje,nesto vise od 29 godina.
Nema razloga da sumnjamo u ove podatke,mozemo ne voleti CIA,ali se oni ne bave sibicarenjem.
https://www.cia.gov/-library/publications/the-world-factbook/fields/343rank.html#RI
Ovo je iz CIA izvestaja koji si objavio i to je "sibicarenje" odnosno pokusaj opravdavanja bombardovanja u punom znacenju.
"Beginning in 1998, Serbia conducted a brutal counterinsurgency campaign that resulted in massacres and massive expulsions of ethnic Albanians (some 800,000 ethnic Albanians were forced from their homes in Kosovo)."
A evo sta pise "Guardian" na primer gde navodi izvestaj prvog stranog patologa koji je dosao na KiM odmah posle povlacenja vojske i policije..(sada imas i knjigu Helene Rante, patologa iz Finske koja je radila obdukcije poginulih terorista iz Racka gde javno kaze da je izvestaj pisala pod pritiskom Vilijama Vokera).
"NATO’s original estimate of 100,000 ethnic Albanians slaughtered, later revised downward to 10,000, turns out to be considerably exaggerated.
Dr. Peter Markesteyn, a Winnipeg forensic pathologist, was among the first war crimes investigators to arrive in Kosovo after NATO ended its bombing campaign.
“We were told there were 100,000 bodies everywhere,” said Dr. Markesteyn. “We performed 1,800 autopsies — that’s it.”
Fewer than 2,000 corpses. None found in the Trepca mines. No remains in the vats of sulphuric acid. Most found in isolated graves — not in the mass graves NATO warned about. And no clue as to whether the bodies were those of KLA fighters, civilians, even whether they were Serbs or ethnic Albanians.
No wonder then that of all the incidents on which Slobodan Milosevic has been indicted for war crimes, the total body count is not 100,000, not 10,000, not even 1,800 — but 391!"
https://www.theguardian.com/world/2000/aug/18/balkans3
Nije ovo prvi put, ne znam koliko pratis tematiku vezanu za USA i njihove "dokaze" ali evo jos par primera koji ti mozda budu zanimljivi.
Ova epruveta kojom je na sednici Saveta bezbednosti UN mahao Colin Powell je "dokaz" da Irak poseduje hemijsko oruzje..rezultat znamo, zemlja u rusevinama i stotine hiljada mrtvih..
A ovo je njegov govor tada.
"POWELL: My colleagues, every statement I make today is backed up by sources, solid sources. These are not assertions. What we’re giving you are facts and conclusions based on solid intelligence."
Ima jos takvih "bisera" a ovo mi je jedan od omiljenih..
"Krunski dokaz" da je Iranska nacionalna garda napala tankere u Omanskom zalivu..
Posli na godisnji pa ajd usput da napadnu neki tanker...
Evo jos jedne "ekskluzivne reportaze" koju je radio Bernar Anri Levi "pod paljbom srpskih snajpera u opkoljenom Sarajevu" kako je opisao svoju reportazu..
Prva slika je ono sto je objavljeno a druga, gde se vide ljudi koji normalno hodaju je "otkrivena" i objavljena kada je rat vec uveliko bio zavrsen, ali je odradila posao u formiranju javnog mnjenja.
Ovo je isti taj Bernar Anri Levi dok je drzao tribinu u Beogradu..dobro pa je prosao samo sa totrom na glavi..
