TS354C EPA crate 35hp, 4x4 ( vuca na sva 4 tocka), 4 cyl shuttle shift roll bar canopy. Huge saving. Now special pick up price US$7595 only! = 5425€ + 2100€ utovarna kasika sirine 148 cm i 700 kg kapaciteta. Sve zajedno sa carinom i porezom 7525 €
TS354C Spec
Tractor Model TS354C
General Specification
Type 4x4 wheel
Rated Traction Force (KN) 7.84
Constructional Weight (kg) 1580
P.T.O. Max. power (kw) 22
Front Wheel Tread (mm) 1180(adjustable)
Rear Wheel Tread (mm) 1100(adjustable)
Wheel Base (mm) 1840
wheel type F: 6.5-16 R: 11.2-24
Minimum Turning Radius(m) With One-side Braking 3.8+-0.2
Without Braking 3.0+-0.2
Ground Clearance (mm) 320
Overall Dimensions L x W x H to the top of muffle (mm) 3162x1445x2020
Engine
Type Yd485
Bore x Stroke (mm) 85x90
Rated Revolution (r/min) 2300
Rated Power (kw) 25.7
Max. Torque (N.m) 108.0
Speed of Max. Torque r.p.m 1600
Fuel Consumption (g/kw.h) <=260 g/kw.h . Znaci 22 kw X 260g(max) = 5.72 kg/h pri punoj snazi!
Lubricating Method Pressure and Splash Lubricating
Cooling Method water cooling
Transmission
Clutch Two Stage
Gear Box (4+1)x2 Spur Gear (4+1)x2 Compound Shaft
Working Devices
Lifter Tilling Depth Control Draft Positional Adjustable
Max. Lifting Capacity (KN) >=4.96
Suspension Type Three-Point Cat I
Speed of P.T.O. (r/min) (540,1000),(750,1000),(540,750)
Ma nesto se mislim 35 ks, 4X4, moze da kosi, moze da vuce samoutovarnu prikolicu, ima kasiku za ciscenje stale, pa ne moze da bude bas tako los....?
I cena je super!
Ali,....ali u Americi!
Verovatno da tamo( u USA) nemaju svoje traktore pa nemaju sta da stite carinama
TS354C Spec
Type 4x4 wheel
Engine
Type Yd485
Transmission
Clutch Two Stage
Working Devices
I cena je super!
Ali šta da se radi, živimo u takvoj državi. I nafta je pala na svetskom tržištu, samo je kod nas, nešto smešno, pala cena njenih derivata. Umesto da skinu cenu benzina 15% kao što su rekli, cena je pala za cirka 7 dinara!
